Here's what yours should look like at the rear of the engine(you might have to take a cover off).
Just take the white wire off and tape it. Hook a new wire to where the white wire used to be, run it into the cab, and hook it to a momentary pushbutton. Hook the other side of the pushbutton to a good ground. This will manually activate the glowplug relay, and take the glowplug "brain" out of the circuit.
