If you get some MLS gaskets made by cometic then you are going to need a very smooth surface for mating. You will likely need to have teh block decked to remove any imperfections.
Copper coat is some good stuff, I used to use it years ago, but for a real good seal you might want to try some spray Hylomar instead. It is applied at the factory on most of the new high tech european diesels head gaskets and they learned that trick from a bunch of us euro diesel mechanics who have been coating the things with teh stuff for years. The hylomar unlike all other sealers, stretches and forms a curtain if a temporary localized hot area causes an uneven expansion so fluids are retained and then when everything goes back to it's normal shape it compresses back. Other sealants simply separate if stressed too far. There is a reason that it is the factory sealant on Rolls Royce jet aircraft engines.
Gary you always make me feel better. I got snowed in today,
