Brown Truck Under the Knife Project - Engine
dyoung14
Is getting worn out
spencer,tn
i belive the 83 model 6.9 already has a lower compression, correct? like 20.7:1 i think?
6 Nebraska IDIs
^^^ Yep, you're correct. So I hadn't really considered dropping them any lower than that.
Thanks for the props on how clean they turned out. That's like 6 hours worth of work right there. lol Enough that I wanted to pat MYSELF on the back when I got done. LOL
I will hopefully be seeing the intercooler setup in the mail today or tomorrow. The condenser mounts directly to the intercooler making that little part a breeze. I'm sure I'll have to do some cutting and stuff to mount it in my radiator support but that comes without question.
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
this means more boost with head studs correct:D
Not really...the difference in compression ratio's negligible. The A engine's 20.7:1 and the B engine's 21.5:1. I imagine you could safely get SOME more boost, but I honestly don't know how much....but I imagine it wouldn't be more than a couple of PSI difference. It's not like you can safely run 30 PSI ;)
And, cool re: the condenser/intercooler! ;Sweet
dyoung14
Is getting worn out
spencer,tn
i thought later 6.9 had 22.5:1, and 7.3 had the 21.5:1, and my next question would a truck that come out in 10/83 still have the old engine cause i have one:D
The Warden
MiB Impersonator
The 21.5 number came from a Ford publication dating to 1985, so I would assume it's accurate (although I can't say for 100% certain).
As to your engine...I'm not sure. My truck was built in August '83 and has an A engine, but I had an '84 model year van (don't remember the build date) that had a B engine. Simplest way is to look at the emissions sticker on the valve cover. If it says A170, it's an A engine; if it says B170, it's a B engine. Another way to check is to look at your engine serial number. If the s/n's under 59209, it's an A engine...anything higher and it's a B engine.
Sorry for the thread hijack :angel:
The model A engines were in production until mid 84' I believe. So yes, you should have one. ;Sweet
Dsl_Dog_Treat
Decatur,MI
Hey Mel ya got an idear what the serial numbers for those "A"'s would fall under?
Mater may have one that would fall into that category.:sly
Administrator Moderator
Threadjack on.....
dyoung. Did you get the 86 "back" or did you get a different truck? I remember a thread about having a problem with the one you had?
threadjack off......
tke395
