Coyote_Red
It's been a while since I updated this thread but I finally have time now that I have settled back in the swing of classes. Now it is show and tell time.....
I did a little horse trading with a friend and got his truck that was in an accident.
Once I got my bed off I noticed the monstrosity of a gooseneck hitch that had a weld bead thrown under it and called good enough. I cut that plate off and threw that on for a scrap pile and am saving that for a rainy day when little bit of thermite will make good use of this plate.
The new cab is starting to make a recovery with some sand blasting. It needs a few patches but is a far cry from what I got.
The bed needed a little bit of patching on the inside where it started to rust through. My dad seam sealed the outside to prevent water and EFFING SALT from seeping through the patch.
Every truck I have owned has had wiring issues. My wheeler was hacked by the previous owner. My black truck had a small electrical fire that was fixed at the dealer. My dually..... well... it seems that their theory was buy the 30 amp fuses since you get more amperage for your money. I pulled out 11 30amp fuses! The truck's panel only calls for 3!!!!!! I wonder why they had to replace the wires to the rear lights once and the second set started to burn up?
Like my headlight switch?
