I finally got some time to update this thread on the progress that has been made.
Finally got the body work on the cab done, the drivers floor pan hole cut out and patched in, the grab handles mounting holes ion the C-pillar filled and smoothed over, cab corner patched up.
We needed a way to easily move the box around in the garage since we have been working with limited space so the boat got set off the trailer and the box placed on.
Things are starting to come together as primer is being sprayed.
As we sanded the high build primer down we noticed a few low spots that we were unhappy with. Two steps forward, one step backwards. Even with having to go back down to bare metal the results of not fixing the issue right would have drove me nuts for years to come.
With this still being a truck still I decided to skip the delicate and brittle automotive paints and use Majic enamel based tractor paint and hardener that is more resistant to chipping and scratching. A few problems arose here as to ensure a quality finish we decided to lay the primer from Majic over the high build Rustoleum primer. This is where we took five steps back as the Majic primer never seemed to cure. Even after 24 hours you could scrape the stuff off with a putty knife. We ended up stripping the primers back off the cab and going down to bare metal. I don't know what is in this Xylol stuff but does it ever remove paint, even some underlying factory paint and primer rubbed right off. After all of this and about months worth of night and weekend work we finally got the paint to come out how we wanted.
This is all I have for pictures right now. The truck is currently in storage as I went from my work term for school back to actual classes in October. I am now back at work and funds are getting easier to come by again. Now it is down to the little things and details to finish assembling the body when things get a little warmer. Small things like resealing the oil cooler and painting the engine, finishing the paint on the inside of the fenders and hood will be happening over the winter time.
