Markinter
User Registered
I'm loosing brake fluid somewhere.
The last day I drove my truck I noticed the pedal was low so I checked the fluid level and yes it was real low. I didn't drive it for a few days and the pedal went to the floor and the brake pressure alarm went off. I just put more fluid in and pumped the pedal and the pressure isn't coming back up so I'm assuming I need to bleed the air out. I looked around underneath the truck and I can't see any leaks. I had the rear brakes completely done last fall.
Any ideas on what to check and tips on bleeding the brakes? I have disc brakes all around. Rears have new rotors and seals and calipers.
