FordGuy100
I've been having this problem on and off, but its getting way worse this time
Symptoms: Peddle goes all the way to the floor, there is no "pumping" you can do, it goes all the way down to the floor and engages the rear brakes, which makes for some hairy situations. I'm loosing some brake fluid somewhere, not much, but in a couple weeks it will be down half an inch. If I slam on the peddle I get it to use the brakes normally for a second until it fades away and goes the floor. If I do it really fast and hard it will slow my truck down maybe 5mph, then goes away.
What do you think would cause this, its getting really annoying
