Boost on 6.9/7.3 idis
hacked89
Bucks County PA
One day I want to put a mechanical dt466 or an 8.3 Cummins in a bricknose @Nero aren’t you a medium duty tech? Which do you like working on more?
94f350
Princeton MA
This the same reason I like spending money and effort on them.
If OP is just looking for an engine that you slap some upgrades on and it puts down good power then he should build a fummins
Yeah I was hoping you wouldn't say thay but you're probably right. It's whatever, I can live with my 180 ish hp. It's just a work truck anyways.
Heavy duty mostly, but can do medium. I personally prefer Cummins over any other manufacturer, especially when it comes to newer engines. Sorry Cat, you left the OTR industry years ago!
KansasIDI
Hopelessly addicted to IDIs
Wilsey, KS
Want a little extra oomph, give the IP a couple flats. Keep your foot out of it and you won’t melt anything. Install a pyro and then you’ll know just how much you can push it.
I don’t have a pyro, but I only gave it 1 1/2 flats and I do NOT pull with it. I also don’t keep it on the floor anymore. It runs so much better now.
03wr250f
Hamilton/Montana
Personally I couldn't. A simple turbo will wake these engines up incredibly even at 7 psi of boost.
It makes the truck way more drive able.
It is not cheap to make big power out a idi, as someone who has been there and done it
110cc, stage 1 injectors, stage 1 turbo, intercooler, south bend clutch, cam, valve springs, studs, custom intake manifold, water m3th, cold air intake etc
But I still recommend turboing any idi
KansasIDI
Wilsey, KS
I assume it is N/A not turbo?
KansasIDI
Wilsey, KS
Wait… duh that is stock for a 7.3
Nevermind. Next time I will think first
you dont want a dt466 in a OBS. thats a **** load of work, but a DT360 drops in
I've seen YouTube vids of dt360's dropped in before. Pretty neat.
Rdnck84_03
Kansas
I read the build thread several years ago but it couldn't remember for sure which engine it was.
James
seen a couple 360 builds.
my buddy tried to do a 466C in a 86, but lost interest, had to be chopped 5 ways from sideways...
Austin86250
idaho
I’m not familiar with the dt360 can someone enlighten me as to why it’s a worthy swap?
It's a straight six that was made as a competitor to the 5.9 Cummins, does about 170-190hp. Mostly used in farm/industrial equipment.
HarleyCummins
