I feel I should clean the coolant side of my block after the overheat-burndown. My block is bare and I have fabricated all the needed coolant hydro plates so I can pressurize or power wash the block. What would you guys suggest me to use for this? Pool Muriatic acid? 4 to 6% H2SO4 and distilled water? or what. I can clean out everything because the block is bare And all the passages can be power washed out. The freeze plugs are stainless and they hold 35 lbs of air pressure. Been down that road before...![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
