Blinking headlights
Cheaper Jeeper
Kent, WA
After the headlights on my truck have been on for about a half hour they start cycling off-on-off-on-off about once every second or two. I've seen references to other people encountering this problem, and IIRC the solution was replacing the switch.
What I can't remember for sure was whether it is the dash-mounted (on/off) power switch or the floor-mounted (hi/low) dimmer switch.
It's the dash switch. Replace it, and then do a relay mod on both the headlights and clearance lights, and you'll never need to replace it again.
