m67tang
My goal right now is to run 50/50. When I first started I had about 25% ATF in my mix and all was good. Now my mix is 50% motor oil/ 50% diesel #2, and Howe's diesel treat, no more ATF supply. So now I am getting more smoke and less power, and higher EGT's. What went wrong? Is it the lack of ATF?
I have not been using RUG at all. Would adding RUG solve my smoke problem and lower EGT's? should I add 25% kerosene in my mix to make it better?
I do not have the wmo supply to run W85 for my car and 2 trucks and tractor & still fuel my waste oil heater, so help me make a good 50/50 blend.
