Best Online Vendor For Parts
HS108
Diesel Newb
Connecticut
So no go on the facet pump? I guess I've been watching to many you tube videos, seems like it was the way to go.
They used to be all the rage, but over time have proven to not actually be the holy grail they were once thought to be.. IMO
For what it’s worth I run a mech lift pump, got a new Carter brand one and it works good so far.
That's the feelings these days.
You shouldn't get your build info from You Tube. I watched one video where the guy secretly turned up the IP on his friend's(?) truck one flat, and the driver acted like he had just put a turbo on the engine. Yes it might make a difference, but not that much of a difference.
These are the three recommended on the Forums.
YachtTech82
Friday Harbor Washington
Have spoke with Justin @ R&D, he doesn't have any but is expecting some soon and classic diesel doesn't have any either. Moose diesel I have never heard of until now so I check them out, looks promising and theyclaim to have injectors in stock
I can vouch for moose. I just got an email from Justin that he is catching up on some back work then he's going to do injectors. He has a set of mine he's repairing.
I havent heard of them so I'd lean on the side of probably not..
YachtTech82
I found the exhaust manifold gaskets and thermostat at a napa today but no luck on anything else. I will be putting in some order from a few vendors. What about coolant? I have easy access to delo ELC, is that any good for these engines?
ihc1470
Idaho
I would find something with SCA add to it. You want something for a diesel engine.
