Best e4od fluid?
Slicknik
Burbank, CA
Dextron-lll/mercon ATF
Or
“Type F” (ATF oil that has more zinc )
Slicknik
Burbank, CA
@chillman88 , I though so too but from the ford guys I deal with and a couple local transmission shops , they all run dextron/ mercon lll in the e4od and merconV in the c6
Mercon V is probably fine
Administrator Moderator
Anything Mercon/Dexron or Mercon V is fine for the E4. Mobil 1 is a good choice for a synthetic.
Hey Speeder,
I read something once and wanted your opinion. Someone was talking about fluids and making an E4OD/4r100 last longer. They said their "transmission guy" only used John Deere HyGard or IH HyTran in the E4/4r transmissions. They said they used it in their transmission, and it seemed to work well, shifted nicely and the transmission lasted a long time. I know that HyGard/HyTrans are some EXCELLENT fluids for what they are used for (tractor transmission (shuttle shift deere, and hydro IH) and hydraulic system). I pretty much dismissed it as internet lore, but I did wonder.
***PLEASE NOTE: I am asking a curiosity question, I'm not recommending the use of HyTran/HyGard in your truck!!!***
saburai
Is the Mobil 1 worth the money? Much better thermal resistance? I'm about to install a updated rebuilt tranny. I bought it from a member here, he had it rebuilt and then wrecked the truck a few years after. It's been sitting for a two years, I've got a rebuilt HD torque converter to go in as well. Question: should I drop the pan and replace the filter? It's got a Mag-Tech pan w/ a drain plug, so I can just dump the fluid. I've read about the filters coming loose and the fix is to retrofit some clips. What's needed to do the filter service? 17 quarts of fluid is what's needed, correct?
Hey Speeder,
It's been a long time since I've seen any Hy Trans, but it seems like it's thicker than ATF. If it is, it seems like it may cause trouble in cold weather. I may be wrong of that though.
chillman88
Central NY
It is. Lots of guys run it because of that. Apparently it makes the torque converter "tighter" from what I've read.
Good, so I wasnt crazy thinking I read that somewhere. I think HyTran is a bit thicker that ATF, but not by much. I know a few drips can make a spot bigger than a Cub Cadet...... I've never seen HyGard, I only deal with the IH stuff.... it's what all the IH Cub Cadet Hydro's (and gear drive's) use.
saburai
Just got off the phone with the guy who built the transmission. I'm pretty confident that he knows what he is talking about.
https://www.fisherautotrans.com
He said that the mag tech pan has a leg to support the filter and that Mercon V is the preferred fluid. Also said that synthetic is not needed. I'd would be better off with more frequent fluid changes. 21 quarts with the converter.
trackspeeder
Stone crusher.
North Branford. CT
You're not crazy.:D Yes it is true. HyGard is a little heavier and has detergents in it to help keep things clean.
trackspeeder
Stone crusher.
North Branford. CT
Mercon V is the easiest to find. Synthetics are not really needed. They are better to use in extreme cases, like heavy towing, or off roading. I forgot to add Valvoline Max Life. Its a little cheaper.
Most important thing to do with any automatic tranny. Keep up with the fluid changes. Dino or synthetic keep the fluid clean.
Don't forget the transfer case if you have a 4x4. Use the same stuff that you poured into the tranny.
