SIKPUP
I installed a used Banks kit on my truck. It looks like the adjusting rod for the wastegate has been moved from the factory setting, I only can get 9 lbs of boost with a loaded 24ft enclosed trailer at 65 -70 mph. It runs up to 9 lbs and opens every time, so I think it needs to adjusted ! Do I make it longer or shorter to make more boost ?
Thank you,
Mike
Thank you,
Mike
:draw
