FordGuy100
My allen screw is mazes out minus a slight bit, less than a flat. Before unplugging the wastegate I could see 1050. I'm doing about 75-80mph before I reach 800.
I wouldn't be so sure bout all that Mr Young.
Fordguy100, what do you tow? running around light truck is not what the engine/turbo/truck was designed for.
Maxing out both temperature and boost with no load other than the truck is not a good baseline for a truck meant to do heavy work.
just saying
With the wastegate still plugged up....towing about 6500 (tractor plus trailer) up some decent size grades where I had to drop to 3rd, I saw maybe 1100*. I bet with a couple more psi (wastegate set to 9psi) it would have been a little lower. Then again if I was running 3rd at the govenor I would have had 15+psi and maybe higher EGT's, who knows. All I know is empty driving is showing a 200* decrease in EGT's with my wastegate unplugged.
Forgive my ignorance, does that just de-activate the wastegate, so to speak and allow all boost to be directed into you turbo? Where is this line?
I apologize for the hijack.
What kind of speed can you hold when towing that weight up a 6 or 7 % grade with your boost and pyro readings above?
Travis..
