tbiagent69
I've been working on my 87 6.9 for the last couple weeks. I bought 10 injectors off of rockauto.com, and had them pop tested. Good thing I did as 2 were bad right out of the box
Problem is I somehow crossthreaded the #1 injector (see my other thread) and ended up destroying the injector. Went to the junkyard, and ended up with some sort of different series of hard line as it was too long and I ended up cross threading that one also, destroying the injector and ruining the compression fitting... again..
So next step is the plumbing of the banks turbo. I've looked at some other threads and seen that it is a T3 turbo? Is there any way to verify?
I've got that stupid box that says banks turbo, not 6.9 turbo like I've seen some others.
Anyway, it's leaking at the back of the turbo. How difficult is this to get to to fix? Would I be better off just having a new pipe built? It looks like the pipes come from the manifold to a junction, then up to the turbo and back down. Looks really inefficient... Does anyone know a common part number I could get one at kragen / jotozone / pepboys?
Also, what should the oil pressure on this clown be? I've got a gauge plumbed at inlet to the turbo and it reads 20 at idle, with a peak of 40 when I'm running down the highway. This seems low, but since it's in the input to the turbo shouldn't it be low?
It appears to be all part of the original banks kit, so any resources or additional information would be appreciated.
