jaluhn83
For those that balanced these engines, how did you do the rods? What kind of weight variance were you seeing? My pistons were with ~3 grams of each other out of the box and are now within ~1, but the rods I just got thanks to riotwarior
are as much as 20 grams apart.
It looks like you can take metal off the bottom of the rod caps and the side of the small end flat, but my concern is that I don't have a good way to measure end to end balance and that seems pretty critical.
are as much as 20 grams apart. It looks like you can take metal off the bottom of the rod caps and the side of the small end flat, but my concern is that I don't have a good way to measure end to end balance and that seems pretty critical.
the chances of that crank matching all your work...pretty damn slim IMHO.
cause if you didn't do that, they are likely off already
