Bad parking switch?
Cubey
Van dweller
USA
This is the kickdown lever/screw at the throttle by the IP.
When you push the throttle down hard enough, it will make your transmission downshift. Hence, kickdown lever. You will have to be at a low enough RPM for it to work.
Cubey
Van dweller
USA
So what does that have to do with my transmission? Now I’m just curious
Oh, I thought I said what it does. Looks like I didn't. LOL
It downshifts the transmission if you floor the throttle. Or it's supposed to anything.
Not sure why it doesn't on my RV. Bad adjustment maybe. The screw lets you adjust it. The pic above is the one on my truck and it downshifts like it should.
Buffetkiller
Washington
Update. New switch fixed the problem. Looked pretty new too must have been a dud part. Also reverse light problem was a small exposed wire on the truck side of that same harness.
tke395
