G.W BUFFALO
Ok so i got my truck running again the other day, and it still runs like crap. I cant figure out why but this is what i've done to it and did'nt help the problem at all. Ok i replaced the feul lines, return lines, deleted the fuel heater and put a new one peice filter on it. I also put new gp's in it and redid the gp wiring harness, bleed the fuel system and cranked it over untill it started..
What it does, well it runs kinda like a pulling tractor. Barely idles and sounds like it's got a huge cam in it. My first thought was maybe i have bad injectors becouse even after it has ran for a few minutes it does not clear up, runs the same "crappy" and smokes like a hell on the 4th of july...
What do you guy's think could it just be air intrusion still happening or could it be bad injectors or maybe something else completely. It does have a reman injection pump on it, with about 20k on it and it never loses coolant or anything.. I should add that you can realy smell unburnt deisel feul in the smoke poring out of the tailpipe. Thanks
