This is not mine I just seen it an Craigslist and I have no idea how to show the add. I think I have seen people on here looking and talking about them. If I am wrong or I am putting this in the wrong place i am sorry.
JOHN
Newville Alabama
I have a Spicer Dana 7231-D 3 speed brownie/aux trans. This unit has under-drive, direct-drive & over-drive "true 3 range over-under drive unit". This is slightly bigger then a sm465 but not by much "same size as nv4500". This mounts behind your transfercase or transmission inline between your drive shafts. This is true gear to gear cast-iron case gear-box no aluminium or electric switches here and less then half the price of a gear-vendors or us-gear unit. All the gears are unworn and the bearings are tight, it is ready to go. It has a large parking brake built on it which you can use or remove if you are matching it with a automatic transmission. It comes with the shifter and linkage to control it with. You can use it as a super low range with your transfercase for crawling or towing or use the overdrive to get better mpg. $1250
JOHN
Newville Alabama
