ATS up pipe question
saburai
Hi Gang!
My first question for the day: Should the up pipe be resting on the corner of the intake manifold/block area? I'm having to clock both sides of the turbo for everything to fit as it should. So should the weight be supported by the oil drain pedestal or should the pipe rest on the engine?
Many thanks!
Macrobb
North Idaho
Is there a flat spot or something that would rest on the corner? If so, it would make sense that it should.
If there's no contact area for it to rest, then I'd try to make sure there's a little clearance.
Unfortunately, I haven't taken apart an ATS system yet, so I can't say off the top of my head. On my Banks systems, there's a little 'pad' on the up-pipe casting that sits on top of the bellhousing spacer/adaptor at the back of the motor.
saburai
Thanks! there are some cast tabs, I don't know where/if there contacting anything. I've got black DEI thermo wrap on it so that makes it harder to see. I'm just mocking things up, getting a feel for how it goes together. I'll look closer at the tabs when I pull it off again.
I don't think it's supposed to touch anything. I'd think that would cause wear issues on the softer part.
If I'm thinking about it right, I think most of the weight should be supported by the passenger's side exhaust manifold. Those two big studs can hold a lot.
sjwelds
Central KS
pretty sure the weight is supported by the oil drain pedestal. When I did mine IIRC I bolted the turbo to the pedestal and then fed the up-pipe up from underneath?? Not sure anymore, all I know is it was a royal pain in the neck.
I think things will become clear when you start going together with it...
Thewespaul
Bulverde, Texas
This is how I've always done it
Bo17
