ATS Turbo Setup
Darrin Tosh
IDI Hound
Grand Rapids, Michigan
I have an ATS Turbo Setup for sale, It is the early one with the rectangle air box. Includes air box, intake, up pipes, oil feed lines, downpipe. I will have pics tomorrow. The turbo has been recently rebuilt and it tight with no free play.
$800.00 includes shipping to anywhere in the US.
Darrin Tosh
IDI Hound
Here are some pics, the turbo looks great, The up pipes will need to be welded, they are very solid, there is no air filter and you will need misc hardware. I may have boost and egt gauges that I can throw in but I have the check on those. There is an egt probe attached.
The air box has been bead blasted and repainted. It is usually black.
What you see is what you get,...
Darrin Tosh
IDI Hound
Did some diggin and came up with a Banks Boost and a Pyro gauge with a dual pillar pod. Here are some pics, this is included with the turbo setup. There is also an pyro probe, some of the fittings are needed for the Boost gauge.
david85
Campbell River, B.C.
My turbo kit has the exact same air cleaner and the part numbers for a fram or K&N filter should be cast into the inside of the case. I opted for the K&N and had no issues getting one off the shelf.
Darrin Tosh
IDI Hound
OK, what type of air filter does it take, and does it come with any oil supply/return lines?
You can see in the pic there is an oil feed line and the return line is coming off the bottom of the turbo
Another option for an air cleaner is to not use the air box and pipe in an open air element, it would also make an easy setup to pipe in an intercooler.
crispy74
