Dsl_Dog_Treat
Installing a set on my buddy's 6.9 as the Moose overpowered stock bolts.
So a call to tech support regarding the sequence to verify sequence as we have discussed in the past about torquing them several times to ensure proper thread stretch.
My answer that was given by ARP tech support is clean chased threads, supplied assembly lube for studs and stud nuts then follow manufacturer torque sequence specs. Over torquing is not recommended nor multiple install sequences are necessary as the studs are set ready to install.
So there it is straight from the horses mouth.
