are 87-91 frames same as 92-97?
HankHill
NY
have a fisher mm1 on a 1988 truck that I want to put on my 93, are the front of the frames on the older ones the same as my 93?
LCAM-01XA
my very own hell
Nope, they ain't not in the front at least - '92-up are boxed from the engine crossmember forward, '91-down are just C-channel. This may or may not matter for the plow mount tho, as it usually bolts to the outer of the frame, and the frame width is the same AFAIK.
adrianspeeder
USAF C-17 Avionics
Air Force
Dover AFB / Harrisburg PA
I know they are different on the '92+ half tons with a boxed accordion frame horn area in preparation for airbags. The swaybar is mounted differently because of this, and I know a reece front mount hitch won't swap. But again I've only examined F-150s and Broncos.
Adrianspeeder
82F100SWB
Sioux Lookout, Ontario,CA
The front of the frame horns is different on the 92+ trucks, the 250/350's are boxed like the F150's, only without the crumple zone. I haven't seen a Fisher plow since I left the east coast, but, with all the other brands I have dealt with, being that the only difference is from the rad support mounts forward, it can be adapted without too much fabrication. The rear part of the push frame that attaches to the sides of the frame will bolt on.
RLDSL
Diesel fuel abuser
Arkansas
I know the bumper mounts are different. But if you can weld, you can always make up some adapters depending on how the thing mounts on there.About all you can do is take a tape measire to your frame and the plow mounts and see what it's going to take to rig the thing.
Diesel_brad
Dunce
gilbert pa
The frames are different from the rad support forward. The 87-91 is an open "C". The 87-91 plow frame bolts to the outside of the frame behind the rad support.
The 92-97 frame rails in front of the rad support is boxed. The plow frame actually lays on the frame just in front of the rad supports. You "probably" can use the 87-91 plow on the 92-97 truck but i'm sure you will need to mod something
fisher had one plow frame for 80-91 and another from 92-97
82F100SWB
The 2wds may not be boxed(a 2wd 3/4 or 1 ton here is a very rare thing) but the rails still have the same basic, different shape to them than the 80-91 frames.
