Anyone got any tricks and tips
86truckpull
ct
Well I'm gonna start getting my 6.9 ready for the road starting tomorrow and from there I wana build a truck I can drive every day but be pretty compettive doing the truck pulls I pulled with my gas f250 and took 3rd place and I wana try and keep my name up on top soo hit me with any tip or trick u may have truck is a 86 6.9 4x4 dually with the t-19 4 speed
You had better stick with your gas truck if you want to keep placing in the pulls. The 6.9 even with a turbo is not going to keep up with the other modified diesels and definitely not a modified 460 gas. You possibly could do it if you poured some real money into it.
86truckpull
ct
Actully pulling isn't alll about power I was running a 1996 f250 with a 351w I out pull built 460s and iv out pulled a few cummins lol they went happy the biggest part of pulling is traction then hp comes next I just wana kknw any trick I can do to the truck ik bout tuning the ips iv doin it on a 90 7.3 I just wana get tips on injectors turbos anything that can free up some ponnies out of these beasts
86truckpull
ct
Some people like the dps stage 1 others say there junk iv read about the moose misters and had them price out they are very pricey ik people on here have there opinions on both but I dnt want opinions or fighting I just want facts
86truckpull
ct
Thanks and iv here'd ppl say that what's the hp gain out of them if any
For the most hp for the buck I say turbo. Moose pump and BB code injectors. Now getting into the engine lets add studs... Porting the heads... Balancing the engine... Line honing or boring the main webs. Decking the block. A Typ4 torquer cam.... Then adding the Moose Mister injectors. The engine will be streetable and the power will be up around 350+ at the crank. Adding drugs (nitrous or propane) will add plenty more hp but driving it daily will keep you busy with the switching on and off the drugs. Water-methonel adds some cooling to the intake charge. Usually blue window washer fluid is whats used.... Installing a set of low compression Mahle piotons could lower your comp ratio plus milling no more than 15 thousands off the tops helps too. Milling much more can ruin the top ring because its closer to the fire... So said Eric, the head of engineering at Mahle International a few years ago. Mostly getting all the crank webs bored or honed straight and then getting the cylinders straight with the crank reduces lots of lost hp because everything is aligned and not dragging. Look at any main or rod bearing when they come out. If the waer is more to one side that showing misalignment and rotating drag. that reduces hp. Having our roller cam is a great idea. If we could install a roller bearing cam bearing that would reduce plenty of resistance to rotation. Lots of ideas on how to reduce internal drag. A good quaility ring is going to reduce drag too. A harder than normal cylinder sleeve reduces drag too. Synthetic oil reduces drag too.....
86truckpull
ct
So my ideas so far are the moose pump and bb code injectors and I was looking into ceramic coated pistons next is turbo dose anyone make just the pipeing or manifolds for the turbo I may beabel the get an hx35for free also wana do arb head studs any one make. Thicker gasket for the heads to try and drop comprestion and again what's the advantage of the bb code injectors
