SD70Ace
Big yellow Diesels
Since my truck is sitting dead out in the yard and the temp is gonna be getting around 30 degrees or less. If I pull the lower raditor hose, will that remove most of the water from block? The truck contains alot of water right now. I cant run the truck due to glow plug tips in cyclinders to get more antifreeze in the block. Will the block heater help any till I can get the water drained? Thanks for any help.
