Am I dead in the water
psy9zach
keego harbor michigan
There is what appears to be a hole in the plate right behind the cover for the IP gear where you put the oil in at. Just wondering if anyone has solutions for how to get a replacement etc or he'll if its a part of the block and at that point I'm dead any help would be appreciated
Sent from my ASUS_A006 using Tapatalk
psy9zach
Here is the hole
psy9zach
So where do you get a dish plug from? If I put a new one in will it blow out?
psy9zach
psy9zach
Is that just like a freeze plug where a circle if so do you think will bend down on there?
Cubey
Van dweller
There is nothing to do but clean up the oil. It's just a low spot, as I understand it. I suppose you could fill in the low spot with silicone if it really bothers you that oil is pooling there.
psy9zach
Well its spilling onto the center of the block and pools at the back underneath where my glow plugs delay is till it drips(where it is at now that made me notice it)
Randy Bush
Great Falls, Mt
If the seal across the front of your valley pan is leaking you would get oil there too I believe. Biggest thing you need to do is find out where the oil is coming from , bad gasket, something loose. clean it up good and watch it.
It's most likely not leaking from the plug. I don't believe that there is any oil pressure underneath there to cause it to leak. Like Wes said, it's most likely the gear cover that is leaking. If it is, nothing that you do to this spot will stop the leak. What this probably is is the left over distributor hole from the gas engines that these engines were based on (somebody please correct me if I'm, wrong on this!). The plug was way simpler and less costly than a new casting just to eliminate this hole. Look at the second gen 7.3 Powerstroke. They don't have a mechanical fuel pump but the hole for it is still in the block with a plug installed in it.
psy9zach
Mine doesn't have a plug at all that hole was just open truck had a bad shock and bouncing don't think it could be been thrown up out of there? There is a trail front to back?
Randy Bush
Great Falls, Mt
I don't believe the IDI was ever built off of a gas engine. Which is why it was such a good engine. Although don't have any specs in front of me, am sure it was designed as a diesel from the ground up.
Sent from my SAMSUNG-SM-T377A using Tapatalk
psy9zach
So from what I can tell the cap is in fact still in there the cover for the IP pump is leaking at the base. Is that something easily changed I hear taking that off can screw with timing and cause worse leaks? any suggestions also if anyone has any glow plug knowledge did all of them have that little glow plug controller 6 pin cylinder or where some of them controlled by just the relay with the busbar? Bc I can't seem to find the controller anywhere in there I was looking for a bad ground as the culprit when I discovered the oil and got distracted by thinking there was a hole in the block
Jimacho
