Riot, I'm not trying to start a ****** match. But I think the wording on the site is confusing, maybe misleading.
Copper absorbs (transfers/conducts), and retains heat better than Aluminum. Thus the copper bottom pots. You don't want your food pulling all of the heat out of the hot pot, when you add it to the pot
The reason HiPo radiators are made of Al is because the Al will conduct heat from the coolant, to the air, faster than copper. = improved cooling over copper radiators.
There is a little more to it, also. Al rads are designed a little different than most copper rads. The fins are either, more compact, wider, dimpled, or some combonation of designs. Thus providing improved cooling VS most copper rads.
