Mark,
I wouldnt worry about the smoke then. Oil being burned has a distinct odor, hard to mix it up with rich fuel. And you say it was light. hehe I was thinking it was a nice cloud--- with the people wanting to kill ya
Light white can be mistaken for blue and so on.
As for coming down the passes, I figured it out. Just took me awhile. Turbo speeds are slow enough while coasting, and with the high altitudes there isnt quite enough air to completely burn what little fuel is in there (the turbo is below the lower curve of the efficency map) so there's your black smoke.
NA engines would be dying for power at similar heights. Also didnt know you were over 10k ft. thought you were around 8500 ft or so on the pass. Turbos will have trouble at slow speeds above 8k or so.
I say just run er.. You should be just fine.
Too bad the truck turbos weren't set up like those on a EMD locomotive. Turbos on those are gear driven at low speeds and then come off the gear train (via overrunning clutch) at 55-65% load or so. No lag on those babies. Clutch fails.... you're screwed... black smoke to rival a tire fire at low speed.
