pybyr
In the process of troubleshooting my intermittent charging problem with the 165 Amp Leece Neville Alternator in my 89 F350 7.3 I decided to double-check the voltage at the "key on" wire that feeds power to the alternator's regulator/ field when the engine is running.
I'd previously checked and found 12 volts there, and assumed that all was good with that.
I've since checked it when the system is acting wacky, and found that the voltage bounces around- sometimes going below 12 volts, down into the 11 point something range, which matches up with the times that the alternator output drops.
I see that the "key on" wire to the alternator goes down into the part of the harness loom that goes right over/ by the alternator-
I have the Ford shop manuals for the truck, but not the wiring diagrams.
Can someone fill me in on the wiring diagram- and even better, if possible, the physical path of the "key on" wire to the alternator so that I can start chasing where the bad connection may be?
Thanks!
Thanks!
