For anyone whose been thinking about popping a brownie in, take a gander at this baby !
It's an air shift 8341D ( or a P-8341D would be the correct way to put that but the owner isnt quite sure
I searched for a couple of years when getting ready to do a brownie in mine , before I finally gave up and had to settle for a 3 speed manual shift. I'd give my left nut for this thing.
The way it's set up you get a deep reduction range, 1st in teh brownie, shift 1-5 in the main box, go to 2nd in the brownie and 2nd in the main ( UD from now), then 3( direct) and 4th ( OD ) then 3 in the main box and UD , dir, OD, 4th and UD, dir, OD. All Brownie shifts are very smooth and simple, dome by a preselect with the air shift switch and a flick of the throttle ( and of course, you dont HAVE to split each gear, you can drive your ZF like a normal 5 speed, or of behind a 4 speed, likewise when empty and you can skip gears, just use what you need, its just REALLY great to have exactly what you need, I know, having 15 gears is wonderful, but having that air shift would be simply heaven.
If I wasn't so friggen broke, I'd be on that thing like a buzzard on roadkill
