The Warden
MiB Impersonator
Quit giving me ideas my wallet can't tolerateOne other question that creeps in my mind is whether or not you could use a 2wd transmission, install the brownie, then unstall a divorced NP205 or similar transfer case so the gears would be useable in 4wd. The Front D shaft may need a carrier bearing at that point.With 4:10's, NP205 and the diesel ZF5, you would have a crawl ratio of 78:1. If you could divorce mount a 1356 with its 2.72:1 low range, you would get 110:1 final reduction ratio.
I would plan on mounting the Brownie where the rear carrier bearing goes like Robert did and keeping the brownie in 1:1 for 4wd duties. The divorced T-case behind the Brownie would be the ultimate though.![]()
Seriously, that would be a very sweet setup IMHO
It's probably a good thing that box is on the East Coast with no shipping...otherwise I'd be sorely tempted...
