spencnaz
- Joined
- Jul 26, 2006
- Posts
- 314
- Reaction score
- 0
I have been trying to track down a persistent air leak in the fuel system of my truck. I have replaced all the fuel lines (the rubber ones) this summer.
I check the connections going to the fuel water separator area (it's been bypassed) and found no leaks.
I put in a clear fuel sight in the line to the engine where the F/W separator resides and see bubbles coming from the engine side of the glass. If you let the truck sit for a period of time, say at least 4 hours, the truck will start for 5 seconds and then die. After some cranking of about 15 seconds it will get fuel and snort for about another 5 before settling down to a smooth idle.
I've replaced the fuel filter recently as part of regular maintenance. My question is that can the Schrader valve go 'bad' as it were and start to leak air into the fuel return system?
I've put in all new injectors, pump and fuel return lines this past summer.
