VincentVega
Alright boys, I'm in need of some help. Air conditioning is a must in Alabama, and I'm currently without it. Over the winter the heater worked awesome. Like, chase you out of the truck kind of awesome. The heat started to roll around and I'm stuck with 2 at 55 AC. The air compressor clutch is not engaging, even with the paper clip jump. (unless I somehow did that wrong). I can set the truck to any of the settings for the air system, and the fan will blow air, its just permanently hot, unless its on vent-cool. Then its just warm. My truck is originally from the Cali High Desert so I'm sure I've got a leak or two, but if I can get the system up and running, I can go from there.
Thanks for the help in advance!
