zigzkidz
How do i convert a air conditioner pump into a air compressor?
actually some members on FSB successfully converted the ford A/C pump to an air pump.
YUP!!!!! brain fart!! been awhile since used one--sassyrel, the other word you were looking for is ------York. I like the aluminum version for obvious reasons, oh an ac pump will make in excess of 300 lbs so make sure the pressure switch and blow off work properly.
if its a axial type--they are asking for problems with continued use
