Air bag questions
Dsl_Dog_Treat
Decatur,MI
Ok guys those that are running air bags on the rear axles I need ya to bear em!
I've got a set I'm trying to get put on Goldie but the rear Reese framerail mounts are in the way. -cuss
Anybody found a safe way around it please share your expertise.:angel:
Diesel_brad
Dunce
gilbert pa
RANOVRU
Virginia
Dont mean to hi-jack too much but I figured why start another thread on the same topic. How would I find out what bags are on my truck? I dont see any writing that I can find on there anywhere?
My truck came with them via the PO.
Dsl_Dog_Treat
Decatur,MI
Thanks Brad.
I'd like to try to make these work first before I go drop some big coin though.
Here's my dilemma.
Dieselcrawler
Professional wrench holder
Quakertown Pa
official puck of NHL?
and comeon, you can figure out how to get that mounted. i got faith.
Diesel_brad
Dunce
gilbert pa
Thanks Brad.
Here's my dilemma.
Either cut off the tab going outward and reweld it going inward. OR call firestone or airlift and get just the top mount
93cc7.3
needs turbo power
plainfield IN
Thanks Brad.
Here's my dilemma.
simple and i have done this before re drill the air bag mount on the top to slide the top mount towards the front of the truck just enough to clear that hitch ... problem solved
tonkadoctor
none ya bidnes
That's what I'd do. Eliminates the risk of a weld breaking from repositioning the mounting tab too.
RANOVRU
Virginia
There are no numbers, but if you have some pics of them
It was kind of dark yesterday when I was looking for some tye of ID. This morning when I took these I saw Airlift. Is that a brand?
Diesel_brad
Dunce
gilbert pa
One problem with that idea. When the bags are deflated and the suspension is cycled, the top bracket will HIT the bottom bracket:eek:
Instructions say you never want less than 10 lbs. air in the bags after mounting.IIRC.
Yeah, Airlift is a brand name. Used to sell them, just as good as Firestone or any others.
Dsl_Dog_Treat
Decatur,MI
Yup theyre still holding up!;Sweet
I know I can do it. I'm wanting to see what others have done and to share some advice.
I wasn't really keen on cutting and welding them to the rail mounts as to keeping those 2 systems separate and individually serviceable.
It's looking like I'm gonna drill the back sides and spacer out the front mount on the upper bag bracket to keep them parallel to the frame rails.;Sweet
So much for an easy bolt on mod. What was I thinking.:D
JU57US
