advice on 460 gas to diesel swap
rrshaly
midwest city ok
My name is Ross and I am new to forums. I own a 1988 ford f350 4x4 crewcab long bet with a 460 and a c6 transmission. I am looking to convert this to a diesel. I am looking to buy a donor truck, 87,88,89. My question is can I pull out the 460 and bolt up a 6.9 or a 7.3idi? can I use the c6 that I already have? I found a 1988 donor truck 2wd for $900 and the guy says that it has a 6.9 in it. I have done some research and I am a bit confused. Did the 88 come with a 6.9 or a 7.3? can I just pull the motor and glow plug controller and wires and the few other misc stuff and bolt that motor right to my tranny and if it is a 7.3 can I do the same thing. Please help???
Dave 001
southern NJ
Remove the 460, the rubber engine mounts, and the engine perches (metal brackets). Use the perches and rubber mounts from the donor truck to install the 6.9/7.3. You cannot install the Diesel using the 460 mounts. They are quite different.
You cannot use the C6 that is behind the 460. You need a C6 that was originally bolted to a Diesel. A C6 from a 460 and a C6 from a Diesel have the same bell-housing bolt pattern BUT the Diesel C6 has a large cutout on the bottom of the bellhousing. The 460 C6 does not have this cutout. The cutout is needed with the Diesel in order to access the torque converter bolts. If needed, I can dig out my Diesel C6 and take a picture.
As far as I know, the 7.3 came out in 1988.
Electrical requirements for the Diesel are rather simple. Assuming a 7.3 style glow plug system......the glow plug relay needs its own cable run from the battery positive post to the large power post on the relay. The harness that came with the Diesel only requires one wire to be energized with a wire that is hot when the key is in the run and start positions. The harness will distribute the power to the glow plug controller, the fuel heater, the high idle solenoid, and the fuel injection pump shut off solenoid. If you are good with wiring diagrams, the picture below is all you'll need. The oil gauge will still function. Just connect the oil pressure sending unit wire from the 460 to the Diesel.
You will need to install a second battery (use the parts from the donor truck). Same goes for the large Diesel starter battery cables. You will also need to install a "Water in Fuel" light in the dash. All you really need is an indicator light. If the light comes on, you'll no what it is....after all, you installed it. It doesn't actually need to say "Water in Fuel". You should also tranfer the low vacuum warning light from the donor truck to your truck. Actually, do yourself a favor and just convert to Hydraboost......they are awesome. Ford really screwed up when they did not put Hydraboost on everything heavy duty 3/4 ton and up.
The picture below shows the 7.3 style glow plug system. This is the early 7.3 system with twin 10 ga wires supplying power to the glow plug solenoid. Later systems replaced the twin wires with a single 2 ga cable. If the donor has twin wires, remove them and replace with 2 ga cable. The twin wires were a big problem and could easily set your truck on fire.
Transfer the 460 alternator directly to the Diesel engine leaving the wires just as they are. The alternator gauge will still function.
Also need to transfer the Diesel radiator and associated parts.
If you get a complete donor vehicle, it's doable. Just take your time and switch everything over. Including the small parts (eg. Water in Fuel light) so that it's done correctly.
I was (at one time) going to convert an '88 E350 from a 351W to a 7.3. I researched it heavily and collected 90% of the parts I needed. But thinks in life don't always go as planned and the convertion never happened. I still have all the parts though........I will use them some day for some project. I really like the 6.9/7.3's and can't stand the new trucks. Sooner or later, I'm just going to have to build what I want. Not what Detroit and the EPA tell me I want. Sorry to rant.
Dave
Dave 001
southern NJ
Forgot to mention......the bellhousing of a Diesel C6 also has a very large counterbore in order to clear the Diesel flexplate/starter ring gear. So if you take your 460 C6 and chop the bottom of the bellhousing off in order to access the converter bolts, it still won't work with the Diesel. It would take a rather large mill at a machine shop in order to add the counterbore. By the time you do that and pay machine shop rates, it would be cheaper and easier to get a Diesel C6 from a junkyard.
Dave
