PM Calvin, he's usually very helpful to the board. I've used an MT254 which does the same thing as that except it converts the cylinder explosion(luminosity) to a signal that can be read by a timing light. The trick with these trucks is that the have no timing marks only a "0" for TDC. What you have to do is dial in(I don't know how this meter works but on most you have to dial in degrees advance on an adjustable strobe timing light). You need to note where the timing is with your offset entered into the meter or light and advance or retard the timing till the flash lines up with the 0 mark with your desired degrees of advance typed in. For example you find the timing mark, hook up your snap on adapter to the #1 injector line and dial in 9 * advance (9*BTDC) and the marks don't line up in fact the flash is a few dime's widths to the right of the zero mark. Your timing is retarded so advance it till the marks line up and the light from the timing light hits the "0" mark at 2000 rpm. Also the timing should be more advanced at idle and when you put direct power to the cold timing advance the timing should immediately become 2-3 degrees more advanced. If it wont advance you may have a problem, also when you give it some throttle the timing should begin to retard somewhat, at least on a stock pump. The moose pumps and other hot pumps change the timing curve so it doesn't fall flat on it's face at higher rpm, but for a stock DB2 you'' see it become more and more retarded as you increase engine speed, this is normal and is to save you from yourself. It doesn't take much movement of the pump to change your timing. Even something as small as a dime's width will have a significant impact. Getting around the fast idle solenoid and brackets, FIPL or VRV and then getting the bottom bolt loose are the biggest tricks. After that the biggest worry is can you get it to stay where you moved it(bearing in mind small movements have big impacts)? It's a great thing to learn and I hope you can get it done. Good luck
