I just got my A/C working this summer and my THIRD compressor is on it's way. The first one was bad out of the box, the clutch sounded like a blender. It was a nightmare trying to get Rockauto to accept the return on that. The second one I bought from Amazon, everything worked great with ice cold temps. I pulled a vacuum, then charged by weight, about 2.7 lbs of R134A on my digital scale. The high side pressures sitting there at idle were about 280 psi and it was about 95 degrees that day. Everything was new. New red orifice tube, condenser, evap, drier/accumulator, low pressure cut-out switch, plus the liquid, discharge, and suction lines with 8-oz of PAG46 oil placed in the system. The only parts I got used were those two aluminum pieces that bolt to the top of the compressor, with the blow-off valve because I could not find them new.
Less than 1000 miles later and my a/c isn't blowing as cold.. still cool.. but not cold. I pop the hood and the clutch is wet, and there is oil scattered around.. including on the hood. It looks like the oil was making the belt slip, maybe the clutch too. I quit using the A/C and checked the charge several days later and it was already down to sub-10 psi (not running).
I don't know what you are buying, but I thought I would be smart and buy a Reman Four Seasons compressor online hoping they would be more reliable than the Autozone/O-Reilly crap. So much for that. I'll pull the orifice when the third compressor shows up just to double check it. I think we are simply suffering from a lack of quality control.. rather than bad fan clutches and clogged orifices.
