MIDNIGHT RIDER
- Joined
- Sep 29, 2005
- Posts
- 4,639
- Reaction score
- 38
In an attempt to track down why my blower switch makes my electronic tachometer go wild, I undertook to have a look at the fan-speed switch.
I removed two screws above the radio and a whole plastic panel eased out in my hands, to be layed aside.
Oh goodie, I can see the whole switch mechanism, held in place by four little screws, no problem.
I remove the four screws.
I jack and twist and wiggle and no way is that switch panel going to come out that hole, where it would make sense for it to come out.
Some moron at Ford Motor Company, in all their wisdom, designed the switch-panel to screw in from the back, behind the plastic dash holder thingie.
Try as I might, I could not get that switch to work out that nice hole that common sense says it should.
I looked at the radio.
Maybe if I remove the radio, I can get the controls out that much bigger hole.
I take out the radio, and guess what---there is a big steel panel between the radio and the A/C controls, no way to get it up there.
Many many years ago, I had to replace the vacuum controlled part of that switch, but I can't remember exactly what I did.
Please tell me how on earth that the A/C control panel can be gotten out where I can examine, and possibly replace, the fan-speed switch.
All I managed to accomplish was to knock out my radio memory that takes about two hours to reprogram.
Thanks.
Thanks.
