94 idi turbo with 87 cab swap revival thread.
SebastIDIan
NW Georgia
F-Superdutys had 4wd transmisssions in them, so you've saved a lot of headache right there ;Sweet
I second cpdenton, handshakers all the way.
Does the speedo work? Being a 94 frame I would assume the VSS is in the rear axle but the 87 cluster is cable driven :dunno
If it does then there's a good chance they hooked it up to the transfer case so just bolt it to the ZF and you're good to go.
morgankshaw
Sacramento, CA
I don't know about the speedo I think you're right. But I'll probably take the cable and cluster from the superduty.
morgankshaw
Sacramento, CA
Is there any stiffening plate I need to ad to the firewall? Thats only thing I haven't found much info on...
FYI, bronco graveyard sells the plates but I have no idea who they are sourcing them from. Could be freebird for all I know.
morgankshaw
Sacramento, CA
Well I hope this isn't a huge problem but I found a crack in the bell housing. I found a guy that says he should be able to weld it for me but he still hasn't seen it in person yet. I'm optimistic that he can repair it he quoted me $150.
Any idea what I should ask for my old e4od when I sell it??
morgankshaw
Sacramento, CA
Thanks. Looks like they should have almost everything I still don't have! Great link
morgankshaw
Sacramento, CA
Have any of you used this plate? Do I need to remove the existing metal work or do the stuffiners just bolt right over what's already there?
all you do is remove the pedal assembly, install the plate, then reinstall it all.
then there are a few fasteners to bolt in.
i had rust in my firewall, so i had to replace the steel, and then i added more support, and welded everything in, but i had everything removed, and i am fond of welding :)
morgankshaw
Sacramento, CA
But if everything is solid and looks like it might have a block off plate for the clutch so I still need the stiffiner? Or is it just for repair?
morgankshaw
Sacramento, CA
Here is the tranny I'm hoping to use. This side has the id tag.
m2rtin
