94 7.3 idi blowing white smoke at 1500 rpm with no power
This is why it is recommended to replace ip and injectors at the same time, with fresh injectors the ip has to work a lot harder.
Chemgrad
NC
When you replace the pump make sure you replace that little rubber o ring on the inlet to the pump. I didn't and had to replace that new pump. Just a heads up that I wish I had thought of. Sucks when a less than a dollar part ends up costing you several hundred dollars. Oh well learn from your mistakes and pass that knowledge on.
Christian9112
California
I replaced my injectors as well. advanced it a little bit until the smoke cleared. 1 of the new injectors was stuck open causing a knocking sound. Is it really critical to replace the IP if I can just advance the timing a little bit? The idle is good. No misfires or anything. The only sound Im hearing is lifter noise.
pwillis
