First: WOW! What an awesome website! I have already learned way more than I thought I could after spending a day searching! Bravo to all those that submit such detailed threads! I'm not a Ford guy, but this truck was too cheap to pass up.
Now, I could really use some more detailed information and/or advice.
I just purchased a '93 F250 x-cab 4x4 long bed. 7.3 IDI and no turbo, 5sp trans. I live in Colorado and the truck is originally from Iowa.
This truck sat unused for about 8 months until the owner determined he would no longer use the truck. The initial reason the truck sat - the driver's front wheel/hub came off the spindle and the tire/wheel rolled under the fender and rocker crushing up into the door - this happened as he was pulling away from having parked a trailer, slow speed. He says that he bought the truck 9/06, put 7K miles one before this happened. He also had done oil, coolant change in that time, and had replaced all of the glow plugs. He used the truck to tow a goose neck enclosed trailer for his rodeo entertainment business. This truck was supposed to replace an older truck, but when the hub divorced the truck, he parked it with no time to fix and recently sold his business. He reported no issues with the truck until the tire/wheel came off. Now, on to the issues.
The truck fired up fine after sitting, a little smoke at idle and a small fluid leak from the back of the engine block. I later determined this was from some very leaky injector return lines and o-rings. These have been completely replaced. I was unable to drive it as the left front was still apart and damaged. I should also note that the factory tach does not work.
The hub failure I attributed to faulty lock/pin rings for the hub nuts in the notorious auto hubs. I've replaced both auto hubs with factory manual hubs and the truck is now mobile.
The first drive: Idles nice, good throttle response, no hesitation or shudder. BUT - it will only accelerate normal to 30 mph in 1st or 2nd gear. Beyond that, it looses power and lots of grey to black smoke billows out of the exhaust. I can't get the truck over 45 mph in any gear. The injection pump seems to clatter a bit louder when trying to go faster, but not too bad...?
In talking to a Ford IDI enthusiast friend (who directed me here) He suggested that I replace the fuel filter and put fresh fuel into the truck as the first fix for this problem. I've replaced the filter, but it did look very recent and it was full of clean fuel when removed. I will put fresh fuel in it later today and report back with my findings.
Could it really be that simple? My IDI friend says his trucks act like that when fuel-starved. Would stale gas allow it to run well until higher RPM's then poop out? Seems to me that it wouldn't idle or accelerate well with bad fuel....
Anyone have any other advice on what to look into regarding this issue? What are the symptoms of a bad injection pump?
Thanks in advance!
Thanks in advance!
