mobilemech
I put a factory cruise unit from a 93 into my 93 but it is not working, I went through the diognostic from the tech section and have come to the brake / clutch circuit resistance problem. I have less than 20 ohms in the circuit but the proper voltage. My question is this; is the brake light switch or the clutch switch differant from non cruise to cruise trucks? I just took the servo unit and cable, did not change the brake switch or anything under the dash, did I miss something? The wire harness had the cruise plug in it so I just hooked it up after I changed the column.
Thanks for any info and help.
