90 7.3 NA vacuum line diagram?
89dieselbko
patton pa
So i have a 4 day weekend coming and got a lot to finish on my BKOs swap, mostly small things, but i ran into an issue...
I dont have a map or any pictures of what vacuum lines run where, dont need names of parts i can figure that you easy enough, i did print a couple of engine bay pics i have found here in the site, but i just want to make sure i can get everything hooked up and running properly.
so if anyone has any pictures and/or diagrams of the 7.3 vacuum lines that would be amazing!
Thanks all
Optikalillushun
Coal Region, Pa
hope that helps.
89dieselbko
patton pa
those are much better pictures then i found earlier! thanks a ton, just printed them up, looks like exactly what i need... now i just need to hope it dont rain all weekend like weather is calling for so i can get the old girl in, hooked up, and running!
gingrass179
phoenix, az
where does the top one in the 4 way go? I see top right is brake booster, bottom left is supply from pump, where does top left go?
89dieselbko
patton pa
it goes to the weird shaped thingy on the inner fender well, by the battery, if im seeing the same line you are mentioning.
ntjapkes
