troy
Ok I've replaced the master cylinder, the abs hydraulic unit under the cab on the frame rail, and I'm sure it was the abs differential sensor not a Vehicle Speed Sensor that I replaced, and the front calipers are new and the rear wheel cylinders were just replaced a couple days ago. I bled the whole system no bubbles... But the rear anti lock light is still on
. The light used to come on and once I started moving forward the light went off, lately the light has been on so I replaced the sensor... My question is was this a VSS sensor or an abs differential sensor?. And also could the trouble code still be causing the light to come on, and how do I clear it?
