2 12v cummins motors both p pump 1st has 256k drove truck 2 days ago runs good had no problems other than has an oil leak from front seal missing turbo and turbo drain and starter $1,600 firm if you don't have that don't call
2nd p pump 12v motor unknow miles runs good no starter manifold or intake has 90hp injectors and no turbo $1,400 firm if you don't have don't call
1st gen cummins non ic turbo tight turbo have down pipe $200 obo
dodge 2nd gen dually bed $800 obo
dodge dually rear axle truck had 5sp 4:10 gears $600 obo
2 ford dually rear axles both have 4:10 gears $200 firm choice out or will scrap very soon
1 dodge cummins 12v 2nd gen radiator $150 obo 1 ford 6.9/7.3 idi radiator $150 obo 1 94-97 powerstroke radiator $150obo
1 set of 87-97 ford crew cab doors gray little rust some dents $40 1set of reg cab 89 ford doors $20 1 set of 87-97 ford crew cab doors no rust a few bumps and dents $75 not a better deal out there on doors
1 87-94 ford diesel front fuel tank with sending unit $40
1 dually flat bed will fit any truck $200
1set of 8 lug dodge dually rims and tires $250firm 2 tires are new
1 set of ford 8 lug dually rims and tires $150 firm
2 ford 6.9/7.3 motors with out ip's missing a few small things $125 each or $150 togather
1 fresh 6.9/7.3 diesel injection pump fresh rebuild $100
2 core 6.9/7.3 injectoin pumps never uesd $50
have 1 front and rear ford diesel tanks no sending units $25 no rust from low mile truck
nice 87-91 front passgner fender $25
nice no rust 87-91 diesel front clip $200 firm
1 ford 6.9/7.3 diesel trans t19 you pull with clutch fly wheel starter and all $100
2 borg warner transfer cases 1 1349 1 1356 $100 each $50 if you buy both
1 87-91 ford hood in good shape needs paint $20
todays's date is 2/22/12 i'm going to scrap everything but 2 cummins motors dodge bed and axle and dodge rims and 1st gen turbo on 3/16/12 there is no holding or saving or anything of the sort it's first come first serve cash is king no trades what so ever not sending pictures of anything but turbo,cummins motors, and 87-91 clip and nice crew cab doors other wise you'll have to look at it your self
call txt 1-765-918-7807
also have ford rear farm bumper with reese hitch $50
2 rear dodge bumpers $50 for one $150 for other both prices are firm
1 front 87-91 bumper nice $50 firm
