NIDiesel
I've got a 87 Ford F-350 with a 7.3 IDI. Needed a set of glow plugs, put in 8 glow plugs and a relay, wait to start light worked like it should, truck started good for about a week. Truck started starting hard (it 80 degrees out at the time.) Ended up putting another set of glow plugs in, still not working right. Relay just continually clicks for about 30 seconds. Went to NAPA got a new glow plug relay and controller, put it on, that one does nothing. No clicks, no WTS light, nothing. On a bench I can hook 12 volts up to the solenoid, hook a 12 exciter wire, I get 12.31 volts going to the solenoid and I get the same coming out. As soon as I hook up the ground the output drops 10.75 volts on both new and old relay/controller set up. My output for the WTS light is 12 volts until I hook up the ground, with the old setup it drops to 7.8 volts and the brand new one drops to 4.2 volts. When the old one clicks I would check voltage and its in and out with every click. Unplugged all the glow plugs and it still clicks, unhooked the glow plug harness from the relay and it still just clicks for 30 seconds or so. The new setup is still junk and doesn't do anything. And i understand that new doesn't mean it works. I guess I'm just wondering if I need to try another new controller/relay setup, if I need to try something else, or just go get a stick of dynamite. At this point I'm open to any suggestions.
