86 6.9 rod knock?? Options??
If you can hear it run, you (or someone else maybe?) can usually tell the difference. It's all in the pitch of the tone and the "crispness" of the sound of the knock.
Diesel knock is something some find hard to find.
What you do is cut out each injector to find out which is causing it.
To cut out, loosen the nut on the injector while it's running. Yes it'll make a mess, but it 'turns off the injector'
Azidiguy
Arizona
Havent heard it run yet, going to see it this coming friday. Im buying it assuming a bad engine. The turbo kit and some other parts are worth what im paying
Lance
