85 cclb f350 cumapart swap
BrandonBerkosky
Dickson city pa
Dropping a big bad 12v in my ferd to see what all the hype is about. I got a 97 12v from a schoolbus. IH cast block. P-pump. Bunch of stuff done i dont know. I bought it off a dude who was getting married so he was selling off all his toys. Poor fool. Running a G56 and a 273d behind her. I know you guys just want to see pics.
BrandonBerkosky
Dickson city pa
Got the diesel conversion motor mounts. I'm not in love but they get the job done.
Supposed to be rebuilt
IH cast block
Stock dodge trans mount i will use with my crossmember
BrandonBerkosky
Dickson city pa
3" channel i bent with a harbor freight pipe bender.
Almost there
BrandonBerkosky
Dickson city pa
Unreal how these things fit. It's almost like it was meant to be
wjamesm
I often thought about using a 12v from a school bus as you can get them relativity cheep . but i heard they have an SAE blot pattern and would have a hard time getting an adapter for it .
BrandonBerkosky
Dickson city pa
Turbo time . Had to choose between an h1c wh1c and an hx35. I ended up cleaning up the hx35 shaft on the lathe and re bushing it. I dont know where the truck is at really so im just gonna run this setup to get a baseline
https://fbcdn-sphotos-h-a.akamaihd.net/hphotos-ak-xfp1/v/t1.0-9/1970640_10204498864616755_4606578313390413033_n.jp g?oh=d0be76fb5397fe9636d62a3df0123029&oe=549A5E84&__gda__=1418996436_09bb2699f406a8df421b3eabff00ad1 5
BrandonBerkosky
Dickson city pa
Like i said i bought it from a dude getting married. He did all the hard stuff. I got it with the g56 already attached he said he had a grand just in the adapter and starter.
BrandonBerkosky
Dickson city pa
Got an ox locker off my buddy. It had seen some abuse . I cleaned up the cross shaft and spiders on the lathe. She's good now. Ready to drag the sled thru the gate.
BrandonBerkosky
Dickson city pa
Waiting on a firewall plate from Jason Moyer then i can put the dash back together. This truck was a 351 auto.
BrandonBerkosky
Dickson city pa
For the clutch hydraulics i used a 94 ford master bc from advanceauto they are always aluminum and i bought a dodge southbend prebled unit from nick dybiec. I used the slave and stainless line from the southbend unit with the ford master. It's all the same bore and stroke so the clutch bled right up and its got a great feel too it.
BrandonBerkosky
Dickson city pa
Got a griffin aluminum rad and cooling fans from the scratch and dent clearance aisle at summit
BrandonBerkosky
Dickson city pa
These nut washer combo things ALWAYS rot away so i made my own from some lug nuts and washers. Then i just faced them on the lathe.
BrandonBerkosky
Dickson city pa
Time to get shafted. Front shaft was made from some old rear shaft parts i had. I ended up running 1350 joints. I robbed a 1350 yoke off of a 70 for the front 60. They are interchangeable.
m2rtin
